I'm designing a 555 timer circuit where I want to control the brightness of an LED array. There is a minimum lux requirement for the array so I need to know the output current when I have a 4.8 V source.
This is a similar diagram. The only difference is I have a 4.8 V source and an LED array instead of an LED.
Without the 555 chip (simple circuit with 7 LEDs and resistors connected in parallel) I have about 140mA current going to the array. I would like to know if the values of resistor and potentiometer at pins 6 and 7 will affect the output current. I don't have tools to measure lux so my only guidance is 140mA current output.
Thanks.
