For a Hcs129s12 micro-controller ADC (please see the image) , the sample-and-hold stage accepts analog signals from the input multiplexer and stores them as a charge on the sample capacitor. The sampling process has two stages: 1. Initially, a sample amplifier (of unity gain) is used to buffer the input analog signal for two cycles to charge the sample capacitor almost to the input potential. This stage reduces charging and discharging the sample capacitor by the signal source. 2. The sample buffer is then disconnected and the input signal is directly connected to the storage node for programmable 2, 4, 8, or 16 cycles. The conversion time of a sample is given by the following equation:
Conversion time =(no. of bits in resolution + no. of programmed sample clocks + 2)/ ATD clock frequency
I have a question about step 2: when the sample buffer is disconnected and the input signal is directly connected to the storage node for programmable 2, 4, 8, or 16 cycles, does it mean that we store the voltages during the time that the sample buffer is disconnected? If so why we assign a register to this task if we never use this data?
