Given a recommended transformer with certain parameters (inductance, saturation current, rms current, dc resistance), how would you go about choosing the equivalent coupled inductor? All the coupled inductors I've seen state their values with the coupled inductors wired either in parallel or in series. However, the flyback transformers aren't wired in either configuration, so you don't seem to be able to directly compare the values.
For example, given the SRF1280-101M inductor, if I were to use it as a 1:1 transformer in a flyback regulator, what would be the equivalent inductance, sat current, rms current and dc resistance?
