I'm designing a board which has -48V input. For the power module, I'm considering using KSTW010A0A Barracuda from GE(DOSA compliant 1/16 brick, Isolated DC-DC Converter)
In the datasheet, there is this figure which shows suggested configuration for EMC filtering:
The problem is:this configuration is intended for three-wire system where there is Vin- & Vin+. But my system is a two-wire one. So my question is how to use this configuration for my design.
I guess the Y-caps will be removed and the choke will be replaced by an inductor? How much caps values will affect by this change? what is the value of new inductor?
Thank you
PS1: In the first place I draw my schematic just like the configuration and obviously it's wrong!
