Assuming `row is an input:
library ieee;
use ieee.std_logic_1164.all;
entity hex_kp is
port (
row: in std_logic_vector (3 downto 0);
coloumn: in std_logic_vector (3 downto 0); -- 'column 'is mispelled
sevenseg: out std_logic_vector (7 downto 0); -- why is 7 segs 8 long?
ca : out std_logic_vector (3 downto 0)
end entity hex_kp;
architecture behavioral of hex_kp is
-- signal row: std_logic_vector(3 downto 0); -- who drive row?
begin -- this was missing
UNLABELLED:
process(row, coloumn) -- was 'column' (didn't match declaration)
begin
ca <="0111";
if row = "0111" then
case coloumn is
when "0111" =>
sevenseg <= "00000110";
when "1011" =>
sevenseg <= "01011011";
when "1101" =>
sevenseg <= "01001111";
when "1110" =>
sevenseg <= "01110001";
when others =>
sevenseg <= (others => '0');
end case;
end if;
end process;
end architecture behavioral;
library ieee;
use ieee.numeric_std.all;
entity hex_kp_tb is
end entity;
architecture foo of hex_kp_tb is
signal row: std_logic_vector (3 downto 0);
signal coloumn: std_logic_vector (3 downto 0);
signal sevenseg: std_logic_vector (7 downto 0);
signal ca: std_logic_vector (3 downto 0);
signal count: unsigned (7 downto 0) := (others => '0');
begin
DUT:
entity work.hex_kp
port map (
row => row,
coloumn => coloumn,
sevenseg => sevenseg,
ca => ca
STIMULUS:
process
begin
row <= std_logic_vector (count(3 downto 0));
coloumn <= std_logic_vector (count(7 downto 4));
wait for 100 ns;
count <= count + 1;
if count = "11111111" then
wait;
end if;
end process;
end architecture;
You were missing the begin
for the architecture body.
You also mispelled column, while spelling it correctly one place.
Your modified code analyzes, elaborates and the added testbench simulates:
Note that not having an else for the if statement based on a particular value of row
causes latches preserving the value of sevenseg
for other values of row
This isn't particularly robust, `row = "0111" is a combinatoric evaluation that can cause glitches. You could consider using the result of the equality comparison as an enable to something with a clock.
You could also get rid of the latches by using an else for the if statement assigning sevenseg
to some value.
