I got problem getting around Verilog. I am trying to create a FSM that displays numbers on one of the displays and on the next state to display a string. I did make the string to be displayed separately and the number separately in 2 projects, but I am getting errors when I try to combine it. What I did was to set an always@ loop and place in there a flag in if else statement with two switch cases but I got error saying that is preferable to get rid of the combinatorial logic loop. Is there any way I can combine both functionalities?
Ok, I will post some code, but the main picture is that I have a master state machine and then I got another state machine. I use the other state machine as input to the 7segment display for a single number. But in a different state of the master state machine I have to display a message on the 4 7segment displays. What I got now is: Here I used CLK in order to make the message
always@(BIN_IN or CLK) begin
if(FAIL==1) begin
case(state)
left:
begin
HEX_OUT [6:0] <= F;
SEG_SELECT_OUT <= 4'b0111;
state <= midleft;
end
midleft:
begin
HEX_OUT [6:0] <= A;
SEG_SELECT_OUT <= 4'b1011;
state <= midright;
end
//same for the rest
end
else begin
case (BIN_IN)
4'h0 : begin
HEX_OUT [6:0] <= 7'b1000000;
end
//same logic for the other cases
Thanks
, and RTL behavior will not match synthesized gates. At minimum, you need to change it toalways@(posedge CLK)
to make it synchronous. \$\endgroup\$
