I have to make LDR based light switch that turn on lights in per-defined light condition. To do this I have to use atmega32 Micro controller. I follow some tutorials and write some codes. the code compile in Atmel studio without any issues but when I run the code using Proteaus simulator code doesn't work
This is the code
#include <avr/io.h>
#include <util/delay.h>
#define LTHRES 500
// initialize adc
void adc_init()
// AREF = AVcc
ADMUX = (1<<REFS0);
// ADC Enable and prescaler of 128
// 16000000/128 = 125000
ADCSRA = (1<<ADEN)|(1<<ADPS2)|(1<<ADPS1)|(1<<ADPS0);
// read adc value
uint16_t adc_read(uint8_t ch)
// select the corresponding channel 0~7
// ANDing with '7' will always keep the value
// of 'ch' between 0 and 7
ch &= 0b00000111; // AND operation with 7
ADMUX = (ADMUX & 0xF8)|ch; // clears the bottom 3 bits before ORing
// start single conversion
// write '1' to ADSC
ADCSRA |= (1<<ADSC);
// wait for conversion to complete
// ADSC becomes '0' again
// till then, run loop continuously
while(ADCSRA & (1<<ADSC));
return (ADC);
int main()
uint16_t adc_result0, adc_result1;
char int_buffer[10];
DDRC = 0x01; // to connect led to PC0
// initialize adc and lcd
adc_init();
_delay_ms(50);
while(1)
adc_result0 = adc_read(0); // read adc value at PA0
// condition for led to glow
if (adc_result0 < LTHRES)
PORTC = 0x01;
else
PORTC = 0x00;
And this is a screenshot of proteaus simulation.
I got this error
[AVR AD CONVERTER] Referance value = 0
I only have basic knowledge of programming micro-controllers and simulation using proteaus. can someone please help me how should I configure this ?
