Wikipedia writes this about calculating the output current \$I_{AB}\$ when finding the Thevenin equivalent:
2a. Replace voltage sources with short circuits, and current sources with open circuits.
2b. Calculate the resistance between terminals A and B. This is \$R_{Th}\$.
But! What if the circuit contains the following (independent) current source and resistance:
+--R---o
I
+------o
I think they could be replaced with a voltage source with the potential difference \$V=I*R\$.
If we calculate the output current before replacing and after replacing the above, we would get different answers! What am I misunderstanding?
to work (not$
). \$\endgroup\$\$
and$$
. I've edited your question to use these. \$\endgroup\$
