Would a LCA110 DIP-6 solid state relay work for switching 330v DC? I cannot find information on the datasheet of whether or not this is suitable for switching 330 volts DC. I am using it to switch 5 80uf 330v capacitors into a coil for a coilgun, using an Arduino.
1 Answer
It's right there at the top of the DS: -
However, If you think it's going to survive your application I'd think again. Here's the hint - look at the load current.
\$\begingroup\$ And the on-resistance may be a problem for this application... \$\endgroup\$– user16324Dec 7, 2015 at 21:45
\$\begingroup\$ @BrianDrummond that might be the only thing that saves it! \$\endgroup\$– Andy akaDec 7, 2015 at 21:47
\$\begingroup\$ Doubt it ... 330V, 35 ohms, call it 10A, 3kw. Subtract a guess for the coilgun inductors and it's still worth filming for Youtube... \$\endgroup\$– user16324Dec 7, 2015 at 21:51
\$\begingroup\$ Yeah I was only joking. It's dead in the water! \$\endgroup\$– Andy akaDec 7, 2015 at 21:51
\$\begingroup\$ I actually did get it to work, ended up using 400v 10A relays which worked great. No video of smoking SSRs sadly \$\endgroup\$ Feb 14, 2016 at 0:37
