I have a dev board with a RJ45 connector which has magnetics integrated. I need put it into a case and mount another RJ45 on the panel, sadly I have only another connector which also integrate the magnetics. If I can use a cable simply connect the RX-, RX+, TX-, TX+, of my board connector to the RD-, RD+, TD-, TD+ pins of the connector on the front panel, but left the CT pins open?
Update:
I've tried that, and it works, at least. But more explanations are welcome here. And is it a good or bad design?
