In preparation to design my own boost converter, I am trying to analyze the poorly-performing 555 boost converter circuit discussed here (so that I know which mistakes to avoid):
555 timer boost converter doesn't meet spec
The circuit is reproduced here for convenience:
The accepted answer's comments suggested that the power MOSFET attached to the 555 has a switching-on time in the microseconds range and a current of approximately 1 mA. While I trust the posters' judgments, they do not explain how they reached those values. I wanted to try to calculate the expected switching time on my own and see if I could reproduce the results.
Using an IRF740 datasheet and an appnote (not enough rep to post the links) for calculating the switching speed during turn-on, I found the following equation: $$ t_{ir} = (R_g + R_{g\_app})*(C_{iss}~at~V_{DS})*\ln(\frac{g_{fs}(V_{GS\_APP}-V_{th})}{g_{fs}(V_{GS\_APP}-V_{th})-I_{DS}}) $$
where:
- \$R_g\$ is gate resistance.
- \$R_{g\_app}\$ is external gate resistance (0 Ohms).
- \$C_{iss}\$ is input capacitance (1400pF @ 9V).
- \$I_{DS}\$ is Drain-Source current.
- \$g_{fs}\$ is forward transconductance (5.8 S).
- \$V_{Th}\$ is threshold voltage (4V worst case).
I made the following assumptions when trying to calculate switching time with the above equation:
- \$R_g\$ is not given. Assume 1 Ohm.
- Input \$V_{GS}\$ is 9 - 1.7 = 7.3 Volts, according to voltage drop from 555.
- \$I_{DS}\$ at maximum is 1.44 Amps (worst case), according to the linked answer.
- Inductor current is constant just before switch, so MOSFET sees 9V across drain and source.
- \$C_{iss}\$ is assumed from chart (25C) on page 3 of the datasheet.
When I do the calculation, my predicted switching speed is approximately: $$ 1.4*10^{-9}*\ln(\frac{5.8(3.3)}{5.8(3.3)-1.44}) = 1.09*10^{-10}s $$
My calculated switching time seems orders of magnitudes too fast, considering the output current calculated is in the milliamp range. Does anyone have an idea of what assumptions I made that do not hold, and what assumptions I should replace? It would be nice if I can get my predicted current and switching speed within an order of magnitude of previous analyses done by others (which I assume to be correct).
