Seems like it is hard to keep the directions consistent. I find that it is always useful to keep the following picture in my mind:
and from this, if the unit is a resistor:
i = \frac{v_{+} - v_{-}}{R}.
Decide if you want to use current into or out of each node. I usually prefer out of, which means that the voltage at the node is always the first term (\$v_{+}\$). This gives:
\frac{\color{red}{v_1}-40}{1} + \frac{\color{red}{v_1}-v_2}{2} + 5 = 0, \\
\frac{\color{green}{v_2}-v_1}{2} + \frac{\color{green}{v_2}-0}{4} + \frac{\color{green}{v_2}-(-20)}{8}-5=0,
This is easily solved. You could use a calculator or a math program, or you could do it by hand, for instance by multiplying the first equation by 2 and the second by 8:
\begin{eqnarray}
2v_1-80+v_1-v2+10 = 0\\
4v_2-4v_1+2v_2+v_2+20-40=0
\end{eqnarray}
so
\begin{eqnarray}
3v_1 - v_2 - 70 &=& 0, \qquad(1)\\
-4v_1 + 7v_2 - 20 &=& 0, \qquad(2)
\end{eqnarray}
or
\begin{pmatrix}3 & -1\\-4&7\end{pmatrix}\begin{pmatrix}v_1\\v_1\end{pmatrix}=\begin{pmatrix}70\\20\end{pmatrix},
keeping in mind that the determinant is \$3\cdot7-(-1)(-4)=17\$,
\begin{pmatrix}v_1\\v_2\end{pmatrix} = \begin{pmatrix}3&-1\\-4&7\end{pmatrix}^{-1}\begin{pmatrix}70\\20\end{pmatrix} = \frac{1}{17}\begin{pmatrix}7&1\\4&3\end{pmatrix}\begin{pmatrix}70\\20\end{pmatrix}=\begin{pmatrix}{30\\20}\end{pmatrix}.
So, \$v_o = v_2 = 20 V\$.
