Change everything for the points A,B
I need to find the equivalent thevenin resistance, everything from the points A,B is exchanged.. however after I construct the image:
It says the answer is Rth = 100 Ohm, but I can't figure out how, would it be different if I move the points A,B between R2 and R3 and R4 and R5 respectively (the points A&B aren't given , I just have to change the rest of the circuit to a thevenin equivalent and just leave the branch where Rp is.)
I know this is a homework like question, but can someone just explain it to me how would I get to the result, or link to some useful tutorial so I can learn it on my own.
You are nearly there so redraw taking into account: -
  • R5 is a dead short
  • R1 is in parallel with R4 and R6
It does work out at 100 ohms BTW
