I want to measure the voltage drop across a shunt, but the ADC performing the measurement will be far from the actual shunt - perhaps five meters.
I'll need to measure voltage drops across the shunt to about 0.1 mV, so stray signals of that magnitude could be a problem.
Can I just run two pieces of 22 AWG wire from the shunt to the ADC, or would something like twisted lair help cancel out noise, and ensure the wire runs are the same length (the latter may not matter since the current flow is minimal - only enough to satisfy the ADC cap).
The environment is a camper van - so it is fairly noisy as it has various DC and AC wiring running all over the place.
