I use I2C communication with two stm8s boards.
My master code:
I2C_GenerateSTART(ENABLE);
I2C_Send7bitAddress(0x30, I2C_DIRECTION_TX);
I2C_SendData(0x61);
I2C_GenerateSTOP(ENABLE);
delay(1500);
My slave address is 0x30. I send 0x61. I analyzed stm8s master board with ossiloscope. I see from lister:
Address:30R
Data: anything
Missing ACK: X(with red background)
My signal from master board with stm8s: [![enter image description here][1]][1]
what could be the problem for missing ack? And, is it true address and data values? Thank you!
And,
My master arduino code:
Wire.beginTransmission(0x30); // transmit to device 0x30
Wire.write(0x61); // sends one byte
Wire.endTransmission(); // stop transmitting
delay(500);
And this picture from master arduino code with ossiloscope:
Here, adress is 30W, but adress of my stm8s master code is 30R. I changed this line of the stm8s master code:
I2C_Send7bitAddress(0x30, I2C_DIRECTION_RX);
//I2C_Send7bitAddress(0x30, I2C_DIRECTION_TX);
But adress is still 30R.
code of this line:
* @brief Transmits the 7-bit address (to select the) slave device.
* @param Address : Specifies the slave address which will be transmitted.
* @param Direction : Specifies whether the I2C device will be a Transmitter or a Receiver.
* This parameter can be any of the @ref I2C_Direction_TypeDef enumeration.
* @retval None
void I2C_Send7bitAddress(uint8_t Address, I2C_Direction_TypeDef Direction)
/* Check function parameters */
assert_param(IS_I2C_ADDRESS_OK(Address));
assert_param(IS_I2C_DIRECTION_OK(Direction));
/* Clear bit0 (direction) just in case */
Address &= (uint8_t)0xFE;
/* Send the Address + Direction */
I2C->DR = (uint8_t)(Address | (uint8_t)Direction);
and
* @brief I2C transfer direction
* Warning: the values correspond to the ADD0 bit position in the OARL register
typedef enum
I2C_DIRECTION_TX = (uint8_t)0x00, /*!< Transmission direction */
I2C_DIRECTION_RX = (uint8_t)0x01 /*!< Reception direction */
} I2C_Direction_TypeDef;
/**************************NOW*******************************************/ I changed my stm8s I2C master code:
I2C_SendData(0x60); //I have no idea, i tried it and works for write/read selection
I2C_SendData(0x61); //my send data
delay_delay(1500);
Adress is 30W, now. It is true because i want to write to slave. Then, I saw this signal from ossiloscope:
This signal is same with Arduino master transmitter.
But, I can't see signal of the data. What could be the reason for this? Missing ACK or another thing? I don't know, but data signal is no of the arduino signal. Missing ACK?
Thank you!
