I'm trying to design a circuit that would be fitted inside large plastic gloves. That when the gloves are cut the circuit produces a signal.
Currently I'm considering having a metal (probably aluminium) lining sandwiched within the gloves that would have its capacitance measured. I can do this buy simply having a tuned capcacitive touch sensor circuit kind of like this. So basically the circuit would produce high when the cut occurs. Though I don't know if this would produce the results I require.
Hoping for some possible suggestions on really how to detect when the plastic outer material is cut without using a processor as this will add overhead.
