I want to make a DTMF decoder and use it on an internal DC phone line. I made a decoder with PIC microprocessor (Black DTMF decoder) that works with signals around 0V. My internal phone line consists of a 9V battery, a 330 ohm resister and a phone, all in a series circuit and the DTMF signal is read from resistor ends. My problem is that the signal is always above 0V (around 3.5V that changes if I use another phone) and I need to shift it around 0V but I don't know how?
Edited: This is my circuits diagram.
Figure 1. Decoupling capacitor for DTMF signal.
You need to decouple the DTMF signal with a series capacitor. It will block the DC component from reaching the DTMF decoder.
Unfortunately you haven't given a circuit schematic of your setup or any component values so I can't be any more specific.
  • \$\begingroup\$ I added the circuit diagram. \$\endgroup\$
    – Vahid
    Commented Apr 7, 2016 at 9:20
  • \$\begingroup\$ So is there still a question? \$\endgroup\$
    – Transistor
    Commented Apr 7, 2016 at 21:25
  • \$\begingroup\$ Oh, there was a problem with pin direction register. It is now working. \$\endgroup\$
    – Vahid
    Commented Apr 8, 2016 at 12:17
