Looking for some clarification on the proper wiring of an AC/DC optocoupler (HCPL3700, datasheet) when working with 120vac.
From what i read online it looks like a need a resistor on the hot side and a capacitor across the DC inputs. Most of the diagrams i see online specify a 47k ohm resistor on both the hot and neutral side, per the datasheet if i'm reading it right the opto can only handle about 5v on the AC input, but i don't believe that a 47k ohm resistor will drop 120vac to 5vac, it should only drop to 60vac of both resistors are the same. So my question is am i reading the datasheet wrong or am i interpreting the circuit examples i see incorrectly?
