Summary: I am using a LM317 to drive a liquid pump that draws 1A. Unfortunately my regulator is dissipating way too much power and getting too hot. Currently my input voltage to the regulator is 12V and I'm trying to create 7V so that's 5Watts! So I bought a heat sink BUT I would also like to drop the input voltage of the regulator a little lower, no need for it to be 12V.
Goal: To drop the 12V input voltage to around 9V for the regulator by using a zener diode, that way the power dissipation is lowered to about 2W.
Question: 1) Could I get a sanity check on my circuit I created? 2) Do I need to worry about the current going through the zener diode because its 1A? 3) Could I just use a 3.3ohm resistor instead of a zener diode at all that way 3.3ohmd*1A is 3.3V drop which should do the same thing.
