So just to give some background I've designed a circuit to suit the following task.
- 12V DC Motor moving a carriage up and down a column
- 2 'End stop' magnets, active-low hall effect sensor attached to carriage
- Motor must move continuously to one end stop, change direction etc.
The physical motor/end stop construction cannot be changed in anyway, the motor and hall effect sensor are part of a pre-existing product
This is just a one off test rig but as I'm relatively inexperienced in circuit design I can almost guarantee I've done it the most awkward/overly complex way. I was hoping that people could provide maybe some insight into design changes
Personally I don't like my 'momentary to latch' circuit using the PNP, relay and inverters but was unsure of another way of doing so and this is the area I'd like critique on mostly. I got some input from another more experienced colleague who mentioned analogue switches or potentially using optocouplers.
Any input is appreciated, thanks.
