I have a ferrite transformer outputting 1.2kV RMS on it's secondary. I have added a diode to do half-wave rectification, and have added a sufficient capacitor (10nF) in parallel to deal with ripple. It's more than enough, according to the formula \$dV = \frac{i}{fC}\$
I'm using 32kHz on the transformer, and I plan to draw at most 500 µA. This should give me a very small ripple.
However, to measure ripple, I tried using a 1000:1 high-voltage probe. It has 1GΩ impedance, and it's rated for 60Hz only. Measuring my rectified / filtered voltage shows a lot of gargabe and a huge ripple, around 800V, but I suspect this is false, given the probe's inability to deal with higher frequencies, probably.
I also tried a voltage divider using 10MΩ and 100kΩ regular 1/8W resistors and a regular scope probe on the 100kΩ resistor, but results are quite similar.
Changing the capacitor or removing it completely changes the ripple just a little, about 10% better or worse.
So, my question: is it normal to get false results with those probes (or voltage dividers) on high-frequency voltages?
Is there a safe and reliable way to measure ripple on this particular scenario?
UPDATE:
Here is the distortion I got on the secondary, after rectification and filtering, to illustrate the question a little better:
After reading the suggestions of everyone, I decided to do a test I didn't do before: I made another transformer, with a secondary of about 170V. That way I could use a regular 10x probe (without any voltage divider), and compare it's performance with the 1/1000 voltage divider, but keeping the 32kHz frequency. 170V is good because it's not too high for a 10x probe, but not too low for a 1000x divider.
Here's the result. First, the secondary after rectification and filtering, measured with the regular 1/10 probe. A very acceptable DC signal:
However, here's the same signal measured with the divider. If we ignore the heavy noise, we can see the same pattern seem on the first picture:
I don't know it this is the only problem with my circuit, but it's clear the measuring method is the biggest one. I will build a 1/1000 probe, using high voltage resistors and compensation capacitors shielded from noise. I can't rely on simple voltage dividers for this thing.
  • \$\begingroup\$ I have seen some DIY instructions for high voltage probes and a few youtube videos. The biggest problem is getting a relatively flat frequency response. Often you form RC filters from the used resistances and parasitic capacitances that mess all up. \$\endgroup\$
    – PlasmaHH
    Commented May 30, 2016 at 19:23
  • \$\begingroup\$ @PlasmaHH, this is what I suspected, because the only test I could do to be sure the probe was working ok, was to measure mains voltage. It measured beautifully, but it's only 60Hz, so this test doesn't guarantee it will also work for voltages oscillating at some kHz. \$\endgroup\$ Commented May 30, 2016 at 20:01
  • \$\begingroup\$ @Marcovecchio. I used oscilloscope probes by Tektronix, rated for 20KV max at 75MHZ(-3db), but they are $1200 USD each. The problem with a DIY version is not the 1G ohm resistors you need, but how to put a capacitor rated for several KV in parallel with it so you get a flat frequency response. \$\endgroup\$
    – user105652
    Commented May 31, 2016 at 0:06
  • \$\begingroup\$ @Sparky256, indeed, now I start to understand the reasons behind the high prices of these probes. And as a curiosity, the HV probe I'm using is borrowed from a friend. He paid around $300 for it, but it doesn't have any capacitor inside, only HV resistors. Not so expensive as the probes you mentioned, but expensive enough to make we expect some level of sofistication, which doesn't seem to be present in it. Now I understand why it's rated for 60Hz only. \$\endgroup\$ Commented May 31, 2016 at 14:44
Yes, without a proper frequency compensation. It happens because resistors have small parasitic capacitance, which can be modelled as a capacitor in parallel with a resistor. These parasitic capacitors form a capacitive voltage divider for high-frequency signals. If the ratio of the parasitic divider differs from the ratio at DC, you will get wrong measurements, since the overall ratio becomes frequency-dependent.
Usually this is not a problem at kHz range. But not in the case of high voltage, which implies high-value resistors. The capacitance of a typical resistor is approximately 1.5 pF, which gives 3.3 MΩ at 32 kHz for a pure sine wave. Because you are using high-value resistors, the parasitic capacitance becomes the dominant factor even at kHz-range frequencies. If a signal is not a pure sine wave, i.e. it contains high-frequency harmonics, the parasitic capacitance dominates even more.
Do deal with the problem, add a compensating capacitor (typically, it is a variable capacitor). To get a frequency compensation the following condition must be met $$\frac{R_2}{R_1 + R_2} = \frac{C_1}{C_1 + C_2}$$
This can derived from the ratio for a capacitive divider $$\frac{\frac{1}{j\omega C_2}}{{\frac{1}{j\omega C_1} + \frac{1}{j\omega C_2}}}$$
The easiest way to test a divider is to look at a divided square wave signal via an oscilloscope. With the right compensation, the square wave looks like the scaled square wave. Without the right compensation, your will see a signal with a strange shape. That's because the ratio of uncompensated divider depends on a harmonic number, and after the division the harmonics do not sum up to the square wave.
I'm not sure that the frequency compensation is the only problem; probably there are other issues related to a noise in the measurement circuit.
Also, typical 1/8W resistors are not suitable for 1.2 kV RMS. The maximum allowed voltage for such resistors does not exceed 100 V RMS, if I remember correctly. Consult the datasheet for the exact value.
edit
One way to get proper division is to use 10 nF capacitor as a part of the divider
Note that $$\frac{100\,\text{kΩ}}{10000\,\text{kΩ} + 100\,\text{kΩ}} = \frac{10\,\text{nF}}{10\,\text{nF} + 1000\,\text{nF}}$$
  • \$\begingroup\$ Thanks a lot for the detailed explanation, @dmitryvm! You made me think about a test I could try: to make a divider with 1M / 1k resistors. Making resistence smaller, I will minimize nasty capacitive effects, and with 1kV at 1M, I would still draw only 1mA from the transformer. What do you think? \$\endgroup\$ Commented May 30, 2016 at 21:36
  • \$\begingroup\$ @Marcovecchio: I have edited the answer to include a possible solution \$\endgroup\$
    – dmitryvm
    Commented May 31, 2016 at 9:23
  • \$\begingroup\$ thank you very much! I'll test it tonight and post the results here! \$\endgroup\$ Commented May 31, 2016 at 14:24
Your voltage dividers, assuming these resistors are safe for these voltages (yes, resistors have maximum operating voltages, too, simply because you can "arc" through/around them), should be correct. I don't see any reason why they shouldn't. 32kHz is really not that high, so parasitic effects (capacitance of the resistor and traces) should be pretty much irrelevant, and since you're not running a couple hundred meters of wire, you probably also don't have a significant radiation of power.
I'd thorougly measure all the individual signals involved here – is the current going into the low-voltage side of your transformer really shaped like you expect it? If you don't do the rectification, what does the output voltage look like?
    \$\begingroup\$ Thanks for the reply. Yes, the signals are not perfect, but look good on the primary. I will capture the scope screen and update the question. I'll also post the whole schematics, showing transformer driver and so on. \$\endgroup\$ Commented May 30, 2016 at 19:24
-1
Scope probes are easy to use but cant always be trusted .I use a capacitively coupled 1:1 high frequency pulse transformer .Then I run RG58U coax to the BNC connector on the scope .This means that I dont need to use the probe . I terminate the coax with 50 ohms when the scope does not have a 50 ohm button .The errors of scope probes are much worse on the 1:1 setting so people generally use the 10:1 setting .The pulse transformer setup is 1:1 so you have better measurement sensitivity and it is safer .
  • \$\begingroup\$ I prefer RG59B/U over RG58 cable for such purposes. \$\endgroup\$ Commented Oct 21, 2021 at 11:47
