The maximum attainable delay is based on a combination of the system clock, and available RAM.
Basically, you can create large variables (e.g. 32 bit ints, 64 bit ints) on an 8-bit MCU by spreading the int over multiple 8-bit ram segments. It takes multiple operations to perform addition or multiplication of such numbers (as you have to iterate over the individual bytes), but speed is not exactly critical here, so this is ok.
So, assuming a 20 Mhz clock, how large of a variable do you need?
I'm making a lot of asusmptions here. First, I'm assuming a clock-instruction parity. Many MCUs require several clock-cycles to execute a single instruction, which would reduce the effective clock-rate. Second, I;m assuming your base counter is incrementing at the same rate as the system clock. This is generally only true for hardware counters. Third, the numbers I am using for things (the length of a year, etc...) are rounded versions of the real numbers. Lastly, this whole exercise is rather silly.
\$20 Mhz = 20\times 10^{6} = 20,000,000\$
Well, \$ \frac{log(20,000,000)}{log(2)} = 24.2534966642115\$ , so you need ~24.25 bits to delay for one second.
2 Hours = \$2*60*60 = 7200~\$ seconds, so you need \$ \frac{log(20,000,000*7,200)}{log(2)} = 37.0672778554286\$, so you need 37.06 (or basically 38 bits) bits of ram to represent a 2 hour delay.
So.... Assuming your microcontroller has at least 5 bytes of RAM, all of the listed devices will work.
For fun, let's look at how long a 64 bit long long
would last:
\$2^{64} = 18,446,744,073,709,551,616 \$
\$ 18,446,744,073,709,551,616 / 20,000,000 =~ \approx922337203685.478 ~~ \$ Seconds
\$ \frac{922337203685}{60*60*24*365} = ~\approx29247.120~~\$ years
So with only 8 bytes of memory, it looks like you're good for at least the next 30 thousand years.
