Is there any symbol for electrical insulation?
Is there any symbol for insulated wire? is there any symbol for non-insulated wire?
As mentioned in other answers, the answer is no, or better, the whitespace indicate non connection. You can see, for example, the difference between the gate in JFET (or base in BJT) symbol and the insulated gate in MOSFET and IGBT symbol.
The only thing I can see in Standard is the following symbol:
No. A schematic diagram shows the logical interconnection of components. Whether any of the interconnections use insulated wire, or uninsulated wire, or a circuit board trace (or NO wire at all, for that matter) does not affect the actual CIRCUIT diagram.
Details like HOW components are interconnected are part of the NEXT step AFTER the schematic diagram: namely the IMPLEMENTATION or construction of the circuit.
Dotted lines around a conductive lines indicate shielding and full lines may indicate an enclosure. I am not aware of a symbol indicating insulation.
You can add a comment/text to indicate that this wire needs a particular insulation. That way you are certain that this critical information is visible in the schematics which is referenced more often than the design or repair manual that may accompany it in the future. Add information like voltage, thickness, kind of insulation material as you see fit [indicating voltage will help emphasize to the future reader that the insulation is indeed important].
The answer is no: no symbol for electrical insulation Because we study electronics and electricity which is the flow of electron in the conductor and semi-conductors
It depends on if your talking about a cable diagram or a schematic diagram. Typically cables are not specified in schematic diagrams because there are connectors on the board. You can find and example of IEC or other standardized symbols here (you can also find examples of the IEEE symbols). You can look at the IEC standard if you want to buy it here. Even building schematics like the NEMA do not provide a cable symbol.
As far as cable diagrams most places do them in house and have there own markings for them. All of the cable diagrams I've encountered usually have a physical representation of the connector and or wire and then call out the material or part number if it is an order able item.
So do what makes sense, anything in a diagram that is atypical should be noted and that is up to the designer. The most important thing for diagrams:
