I was reading the BJT section of The Art of Electronics on page 77 Figure 2.10.B.
Shouldn't the divider voltage sit at 14.4β―V rather than 11.6β―V? the opposite what the author mentioned. Since if π3 is in saturation, the base voltage of π3 should be ~0.6β―V lower than the collector which is 14.4β―V.
The βdividerβ formed by π 2 π 3 may be confusing: π 3βs job is to keep π3 off when π2 is off; and when π2 pulls its collector low, most of its collector current comes from π3βs base (because only βΌ0.6β―mA of the 4.4β―mA collector current comes from π 3 - make sure you understand why). That is, π 3 does not have much effect on π3βs saturation. Another way to say it is that the divider would sit at about +11.6β―V (rather than +14.4β―V), were it not for π3βs base-emitter diode, which consequently gets most of π2βs collector current. In any case, the value of π 3 is not critical and could be made larger; the tradeoff is slower turn-off of π3, owing to capacitive effects.12
Figure 2.10. Switching the high side of a load returned to ground.
12) But donβt make it too small: π3 would not switch at all if π 3 were reduced to 100β―Ξ© (why?). We were surprised to see this basic error in an instrument, the rest of which displayed circuit design of the highest sophistication.
