5
Disclaimer:
I hope that I have not carelessly overlooked a previous post that answers this question; but I definitely have tried, and still find myself a little lost.
Situation:
I have 15 A123 ANR26650M1A batteries connected in series. They have a safe maximum continuous charging current of 10 amps, which is stated to have a fast charge time of 15min. I am about to purchase a programmable active balancing BMS board based on the MAX14921. I also have a Mean Well RSP-1000-48 that supports up to 21 amps. Currently, I have been balance charging my series, with a variable DC bench power supply, with a constant current of 10 amps, and constant voltage at 54 volts, through a PCM board for top balancing. The bench PSU is not charging anywhere near 10 amps, and I am not getting anywhere near 15 minute charging times.
Aside from that, most importantly, when I order the programmable BMS, I want to be able to achieve a charging time of 15 minutes utilizing the Mean Well PSU. I cannot seem to find anywhere that explains how this is achieved.
Questions:
  1. Why am I not able to charge the battery with the variable bench power supply at a constant 10 amps?
  2. How do I charge the 15 batteries connected in series at a constant current of 10 amps through the programmable BMS with a Mean Well PSU? Does the BMS basically get programmed like a programmable charger? Is there some other hardware I may be missing?
I've included links to all of the other datasheets I could find for these cells as well.
I apologize for my ignorance, and thank you in advance.
    \$\begingroup\$ You can't have constant voltage and constant current at the same time (at least not in the context of battery charging). \$\endgroup\$ Commented Aug 1, 2016 at 0:15
    \$\begingroup\$ @immibis, when two devices each having two terminals are connected together, they have to negotiate to find a common point on their VI curve. One device can never set both voltage and current. The other device also gets a vote. \$\endgroup\$
    – user57037
    Commented Aug 1, 2016 at 0:22
  • \$\begingroup\$ @mkeith How does that invalidate what I said? \$\endgroup\$ Commented Aug 1, 2016 at 0:42
  • \$\begingroup\$ It didn't occur to me that the wording may be interpreted differently. In regards to the variable DC bench psu that uses CC-CV; it first is supposed to go at a constant current, and then switch over to a constant voltage. \$\endgroup\$
    – Alex Sky
    Commented Aug 1, 2016 at 1:06
    \$\begingroup\$ What's going on is that your battery voltage is exceeding 54 volts. When that happens, since your power supply gives priority to voltage, your current drops in order to limit the voltage. As a result, it takes longer to charge the batteries. \$\endgroup\$ Commented Aug 1, 2016 at 1:07
You should try charge testing with one cell so as to understand its characteristics. LiFePO4 behaves somewhat differently than conventional LiIon. Once you understand how one cell behaves when supplied by a power supply set to <= 10A and <= 3.8V then you can better understand what your series string is doing.
BMS 'interference': If you are using a BMS then it is essential that it does both what you want it to do and what you think it does. If a BMS is intended for LiFePO4 use and has not been specifically set to your conditions it may eg limit Vcell_max to 3.65 V and thus resist efforts to charge at 10A CC up to 3.8V Vcell_max. The single cell tests below are done without a BMS and the results for single cells monitored during a multicell string charge should not be affected by the BMS under 'normal' conditions.
Note:
Just supplying the string from a supply limited to Vmax x cell_count is not safe as if cells are charge-imbalanced some cells could have voltages applied which are above specification.
Also, if cells are charge-imbalanced, if cells which reach 3.8V first are voltage limited at 3.8V then their current draw will usually start to drop and will prevent lower voltage cells being charged correctly. Repeating this fast charge process without cell balancing is liable to increase imbalance with cycling.
Establishing cell characteristics - Single cell test:
Conditions:
  • Fully discharged cell - Vcell ~= 1.6V
    (essential for proper understanding).
  • 15 minute charge time
  • Cell temperature monitored
  • Ambient temperature x <= T <= y and ideally 20-30 C
  • Supply set to Vmax = 3.8V, Imax = 10A ie
    if load is < 10A then Vout = 3.8V and
    if load is lower resistance than R = V/I = 3.8/10 = 0.38 Ohm
    then I = 10A and Vout = whatever is drawn.
What I would expect to see is:
Current initially = 10A and Vcell initially somewhat above 1.6V start value due to internal IR drop and voltage rising from initial value.
For roughly 10 to 12 minutes Ichg remains at 10A (limited by supply) and Vcell rising and < 3.8V.
At approximately 10 to 12 minute range Vcell reaches 3.8V.
Cell is now about 70% to 80% charged.
Supply now goes into CV mode limited by power supply setting.
Ichg will now probably start to fall, controlled by cell internal processes.
Highest input case Ichg will remain at 10A throughout and total input will be
10A x 1/4 hour = 2.5 Ah. As cell capacity is nominally 2.3Ah and as current efficiency (but not energy efficiency) on charge is usually over 99% then a full 2.5 Ah charge is very unlikely. More likely is that Ichg will drop from 10A to some lower value so that Charged capacity is now >= 96% of maximum (according to the A123 'proper operation' sheet.
Cell temperature will necessarily rise somewhat due to internal resistive heating. It may rise substantially and the cycle would need to be terminated but this would be expected to be unlikely in most cases.
Charging from not-fully-discharged state:
Once you have seen how VI varies with time in the above test starting from fully discharged you can see what a single cell does when starting from partially charge. Of particular interest is liable to be starting from say 5% & 10% charge as this gives an indication of what one cell will do when it gets to Vcell = 3.8V while other cells are at lower state of charge.
What I'd expect to see is that no difference would be observed up to near Vcell = 3.8V (as the supply is current limiting) but before 3.8V is reached the cell may "try to accept" less than 10A, it cannot do so under CC conditions, so Vcell will rise more rapidly towards 3.8V over the last part of the CC ramp. Now 3.8V has been reached earlier in the cycle.
An important point has now been reached - in this one cell test situation the cell WILL sit at 3.8V as the supply is Vmax limited. But, in a string situation, if 3.8V has been provided per cell by a CV system, and if other cells are still at less than 3.8V, and if eg 10A CC is applied, with no other intervention the cell voltage WILL rise to > 3.8V. If several cells reacah tghis point at about the same time, not too much harm may be done, but in an eg 15S string, the cell that gets to 3.8V first will be pushed to above 3.8V and quite possibley to > 4.2V and disaster.
This is where a per cell BMS is vital. Vcell must be limited by the BMS to 3.8V if nothing else does so. There is nothing too special about 3.8V (afaik) as compared to say 3.85V or even 3.9V so if a BMS was set to 3.85V per cell and the string voltage was set to Vmax = Ncells x 3.8V + lead Vdrop + connections Vdrop then all should be well enough.
A simplistic BMS could just shunt current around a cell when Vmax is reached.
More complex schemes can be used.
Multiple cells in series string.
Once you know how a single cell behaves above you should be able to reasonably predict how a string behaves under Icc <= 10A, Vmax = N x 3.8V conditions. It is evident that if cells are clamped at 3.8V AND will not accept 10A (which meaans that their effective resistance must rise) then the whole string will be current limited to < 10A.
It is also highly likely that if an initially uncharged cell will accept 10A at any voltage below 3.8V, then your system with Imax = 10A and Vmax = N x 3.8V is probably driving some cells to above 3.8V.
It seems likely that performing the above tests will give you enough insight to be able to understand what is happening with your multi-cell charging.
As above, key points are: Having cells transition from CC to CV at different times and the effect on individual cell voltages and currents, & ensuring that all cells never exceed rated values.
_____________________________________
Multi-cell voltage monitoring:
The ideal is a per cell monitoring system with digital output input in real time to a computer that can analyse and report appropriately.
A cheap (compared to other costs) and almost parallel input brain-processing system is to use a per cell voltage monitor with display. Analog and digital both have their place in such systems, but a low cost self powered system is possible using off the shelf self powered digital voltage meters avaiable from various Asian sources.
You can buy 2 wire self powered meters operating from eg 3V-30V for typically $US1.20 - $US1.50 each with 3 digit LED displaay and calibrate-it-yourself accuracy.
This is an example only with NO intention of recommendation. Note they say 3V minimum in the heading and 2.5V minimum in the text. YMMV :-).
Image from above site:
You can also get 3 wire input versions with 0- 99.9V (3 digit) V measurement and eg 3-28V power supply inputs. These are provided with Vin, V+_supply, common connections and if Vsupply_min is below the voltage to be measured Vsupply can be obtained from 1 battery further up the string. This is less convenient, gives slightly more chance of fiery or silent or magic smoke meter catastrophe when you get it wrong but allows true 0-xx volt input range.
Ali Express 3 wire meter - AGAIN example only.
Both arrangements imposes a small current load on the cells being measured, but this will be far lower than the currents in question and liable to be neglibgle or able to be allowed for. As the meters will draw power whenever connected the best arrangement is probably a multi cell plug connected into the BMS - either BMS turns off power or meter plug is pulled.
A zillion meters - many other searches possible. Meters with current and voltage also available. Ali Express - MANY volt meters
_____________________________________________
Notes:
For normal LiFePO4 CCCV charging, I_cc is whatever the manufacturer says and V_CV is usually about 3.6V. The CCCV charging system is then similar to that for LiIon (but at lower per cell voltages) with charge termination ending when the cell-determined and decreasing CV charging current falls below some present percentage of Ichg_max. Charge termination currents of 10%, 25% and 50% are common with LiIon and similar probably 'work OK for LiFePO4, - higher % is always gentler on the battery.
With LiIon:
Stopping charging at I_chg = 10% of Ichg_max is "road warrior" mode, battery achieves MAXimum charge and is beaten to death in relatively few cycles.
Stopping charging at I_chg = 50% of Ichg_max is "nice and gentle" mode, battery achieves somewhat lower charge than in RW mode (maybe 90%) but whole of life cycles and gross mAh stored and retrieved is substantially higher.
Stopping charging at I_chg = 25% of Ichg_max is obviously between the two above modes. Probably more enthusiastic and damaging than most people really need.
With LiIon V_chg max is ~= Vterminal_V_chgd and is very close to the safe upper limit for a Li based cell.
However LiFePO4 has a final terminal voltage of 3.6V but CAN be charged over short periods at higher voltages where 3.6V < Vchg < 4.2V.
A123 advise 3.8V for fast charging, 3.85V max "normally" and 4.2V absolute maximum.
    \$\begingroup\$ This has been overly informative, and answered questions I haven't even thought to ask. I appreciate the emphasis on safety, and the time you took to respond in such depth. I have been able to successful accomplish my goal, and I hope this could be equally as useful to others. \$\endgroup\$
    – Alex Sky
    Commented Aug 9, 2016 at 5:23
    \$\begingroup\$ @AlexSky My pleasure. Knowing what you did would be interesting. Given that you originally could not achieve adequate current, I assume that a better understanding of the cells' characteristics helped. \$\endgroup\$
    – Russell McMahon
    Commented Aug 11, 2016 at 16:37
From the linked instructions:
Charge the cell at the maximum continuous charge current until the maximum recommended charge voltage is reached. Apply a constant voltage hold at the maximum recommended cell voltage until the total charge time reaches the fast charge time.
And
Maximum recommended charge voltage: 3.8
So
  1. Charge at 10A until the cell reaches 3.8V (or 57V not 54V for the string).
  2. Then switch to CV at 57V for the remainder of 10 minutes.
  3. Then switch off.
And note the cautions about temperature during this process.
You can do this by setting a lab PSU output to 57V, and its current limit to 10A.
Also note that 57V must be measured at the battery terminals, not the PSU terminals. If your PSU has remote sensing, use it. Don't just crank the voltage above 57V at 10A because when the current drops below 10A you will overvolt the cells.
And finally, they are a little coy about how the battery lifetime suffers under 10A charging, but the graph on the datasheet suggests that lifetime is reduced by higher temperature and higher charge-discharge current.
And post-finally : while this answer assumed the BMS woould be competent to handle balancing between individual cells, Russell raises doubts about that, as well as strongly reinforcing cautions about exceeding cell temperature. His detailed comments are valuable and I hope they will be rolled into a more thorough answer.
    \$\begingroup\$ Dangerous advice, I'm afraid. For CCCV he should (must) use 3.6V max for liFePO4, The 3.8V spec is for "pulse charge" and one needs to see what the factory spec is for that. LiFePO4 can be charged at CC to ABOVE the normal CV pedestal BUT if this is done they MUST then be charge terninated and not put in a CV mode. CC then CV at 3.8V would be a very bad idea. A danger in running the whole string at N x 3.8V is that cells that are still coming up to 3.6V will allow extra headroom for ones already at full charge and drive them OVER 3.8V. 4.2V is the ~= fatal point. TO make pulse ... \$\endgroup\$
    – Russell McMahon
    Commented Aug 1, 2016 at 16:23
  • \$\begingroup\$ ... chargers that go to above 3.8V in CC mode. || LiFePO4 behave somewhat differently to std liIon when full charge is reached if extr V is available. They will climb in CC to 3.6V then suddenly go into rapid V rise mode towards too high. Not much available on web on that. Yet. \$\endgroup\$
    – Russell McMahon
    Commented Aug 1, 2016 at 16:25
  • \$\begingroup\$ @RussellMcMahon : so, A123's "Recommended fast charge instructions" for their own cells are dangerous despite terminating at 10 minutes? Or is it that care must be taken not to exceed 3.8V for any individual cell in the pack? I had assumed the OP's "programmable active balancing BMS board" took care of that : but yes I should have made that explicit. \$\endgroup\$
    – user16324
    Commented Aug 1, 2016 at 18:59
    \$\begingroup\$ I had no problem with anything you said or your intentions. That was meant to be a comment on what may be (and probably are) underlying issues. The draft battery pack safety design guidelines are quite extensive and set the tone early on with their 1st 4 bullet points- MUST HAVE dual software & hardware over V protection per cell. .... \$\endgroup\$
    – Russell McMahon
    Commented Aug 2, 2016 at 13:49
    \$\begingroup\$ @BrianDrummond Thank you so much for the answer, and having the discussion regarding the safety nuances. This was extremely helpful. I'm very thankful, and I hope this could act as a guide for anybody else looking into this. \$\endgroup\$
    – Alex Sky
    Commented Aug 9, 2016 at 5:20
