In this design I have separated the ground plane of the sensing/controlling circuit from the high-power 3-4 amp circuit. This is a current controller.
- The ground planes are joined at the sensing resistors and control signal.
- The Analog ground is provided by a DC/DC converter common.
- The Power ground is the ground of the main power supply.
Did I do this correctly?
Alright so I redesigned the board. I was able to keep all but one trace in the bottom plane. The is also a trench separating some of the high current traces from the control circuit.
I am using both a top and bottom ground plane pour because this board will be made on copper clad; through hole components mounted on top can only be soldered (well) on the bottom layer. Now, this creates ground islands in the bottom layer. I tried to place the vias close to were the components terminate so the ground return path would not be altered that much.
One concern I have is that one of the traces to a BJT base is longer than I want... High input impendence makes it vulnerable to noise. I don't have enough experience making boards to know if this is bad design or not ( shown bellow)
