I made simple board with ATMega8U2 microcontroller for my USB experimenting (I'd like to make MIDI, HID, ... devices). I took inspiration in Arduino Uno. If you look on schematic below, you can see it is almost the same as Uno.
I programmed 8U2 with firmware from Arduino project — UNO-dfu_and_usbserial_combined.hex. Now, if I connect board to USB, I get serial port and it works just like Arduino, so this is perfectly OK.
My problem is: how can I put 8U2 into DFU mode, so I can change firmware without external programmer? If you look on picture, I connected HWB (pin PD7) to ground, so it should be simple — just pressing reset button. Unfortunately, it isn't working.
Am I missing something? Can be a problem in wrong fuse bites?
Edit: My fuses are lfuse=0xff hfuse=0xd9 efuse=0xf4
Edit2:
I checked fuses on chip
$ avrdude -p at90usb82 -P /dev/tty.usbmodem411 \
> -F -c arduino \
> -U lfuse:r:low:h \
> -U hfuse:r:high:h
$ cat high low
0x00
0x00
For programing, I'm using Arduino Uno as ISP and this commant (on Mac):
$ avrdude -p at90usb82 -F -P /dev/tty.usbmodem411 \
> -c arduino \
> -U flash:w:UNO-dfu_and_usbserial_combined.hex \
> -U lfuse:w:0xFF:m \
> -U hfuse:w:0xD9:m \
> -U efuse:w:0xF4:m \
> -U lock:w:0x0F:m
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0xff != 0x00
avrdude: verification error; content mismatch
So I suppose, avrdude did not programed fuses and they are still blank. Is it possible? Because board is working corrently, except DFU mode after reset.
