In order to measure voltage with an Ammeter, the current through the impedance of the Ammeter is measured and the voltage is determined indirectly. In the circuit below the impedance of the Ammeter is \$ R_2 + L_1 \$. The resistor \$ R_1 \$ is there to limit the error in current for a temperature dependent \$ R_2 \$.
Now I want to compensate the frequency dependency of this circuit. For that \$ C_1 \$ is added in parallel to \$ R_1 \$, which I want to calculate.
$$ \frac{\underline{V}_1}{\underline{V}_m}=\frac{R_1||\underline{X}_c}{R_2+\underline{X}_L}+1=\frac{\frac{R_1}{1+iwR_1C}}{R_2+iwL}+1=\frac{R_1}{R_2+iwR_1R_2C+iwL-w^2R_1CL}+1 $$
If all the terms holding a \$ w \$ cancel out, I actually would get a frequency independent circuit.
$$ iwR_1R_2C+iwL=w^2R_1CL $$
But that seems like an impossible task. How could two complex numbers add up to a real one? What am I doing wrong?
