While reversing an old made in Russia power supply I had found these ICs. Here I am attach the circuit I had drawn and the components. The VCC and other power symbols are my assumptions. 16-pin SOIC is 26A14, maybe a transistor array?
\$\begingroup\$ You forgot about attaching the schematics. \$\endgroup\$– Jakub RakusOct 12, 2016 at 5:47
\$\begingroup\$ If you are not sure that it is a semiconductor: It MIGHT also be a shunt resistor with two additional connectors for voltage drop measurement and two connectors for a built-in temperature sensor. \$\endgroup\$– Martin RosenauOct 12, 2016 at 6:27
1\$\begingroup\$ Please go on your reverse engineering and draw a draft schematic (at least a small portion of the whole circuit). Draw this component as a 4-pin-box and show the surrounding components with connections. Then we can guess what it is and its purpose. \$\endgroup\$– Rohat KılıçOct 12, 2016 at 7:51
1\$\begingroup\$ I've added your schematic and other picture to this question. Please delete the other question. \$\endgroup\$– JREOct 12, 2016 at 8:25
3\$\begingroup\$ What a gorgeous military-style hermetic packages those are! \$\endgroup\$– Spehro PefhanyOct 12, 2016 at 9:02
Show 5 more comments
1 Answer
Producer of 26A14 is TEF in Tomilino, of 26A22 is Kremniy from Bryansk. I am afraid it is military design, and you may not be able to find datasheets for the devices. However you can try registering on TEF's site and see if it will give you access to its library.
\$\begingroup\$ Thank you very much. At last i could able to find the manufacturer. I will login into TEF. Anyway 12A22 info still not available. Thank you once again. \$\endgroup\$– srinivasOct 13, 2016 at 6:35
