What is the numer at the fourth row on the front side of Intel i7 CPU? (pictured)
I saw two Intel CPUs in the store described as "Core i7-6700" but have slightly different prices (both OEMs). Only the difference I found is the numbers on the front side.
P.S. I'm already guessing it is kind of a serial number but not sure.
That is the Finished Process Order serial number, and is essentially a lot number. It is used by Intel to determine warranty information.
Source 1
Source 2
  • \$\begingroup\$ Could you please also explain what is the number on 3rd line? Thank you! \$\endgroup\$
    – rook
    Commented Oct 14, 2016 at 11:51
  • \$\begingroup\$ Other than the "SSPEC", which is what the first source says? \$\endgroup\$ Commented Oct 14, 2016 at 11:58
  • \$\begingroup\$ I got it, Just first source is temporarily unavailable. \$\endgroup\$
    – rook
    Commented Oct 14, 2016 at 12:00
  • \$\begingroup\$ Btw, it is temporarily unavailable in IE browser) Thanks! \$\endgroup\$
    – rook
    Commented Oct 14, 2016 at 12:02
  • \$\begingroup\$ Try here then. \$\endgroup\$ Commented Oct 14, 2016 at 12:03
