14
This old, crusty inductor found in an old Iskra (Yugoslavia) TV intrigued me, and I was hoping that someone could tell me what's the story behind it's design.
I don't know if the pictures are descriptive enough, but inductor's "head" is magnetic, and the plastic casing is "hugging" another ferrite cylinder with small square hole in the middle.
It's unlike any inductor I scavenged this far, and while I do understand how inductors work, I can't figure out a useful purpose of this arrangement.
  • \$\begingroup\$ Maybe it's a miniature line output transformer? \$\endgroup\$
    Commented Nov 9, 2016 at 11:37
    \$\begingroup\$ Hello again! I don't think so, it only has one coil, the other existing pins are used for sturdier PCB connection. \$\endgroup\$
    – Njubster
    Commented Nov 9, 2016 at 11:49
    \$\begingroup\$ Having a good understanding of old tv sets. I would like to know in what part of the circuit you have found it. It could be a linearisation inductor \$\endgroup\$
    – Decapod
    Commented Nov 9, 2016 at 12:01
  • \$\begingroup\$ Unfortunately, I was a lot younger when I salvaged it, and saved it as a curiosity, so I cannot really remember :/ Someone else suggested the same thing you did, so I guess we're close! \$\endgroup\$
    – Njubster
    Commented Nov 9, 2016 at 12:10
  • \$\begingroup\$ I would suspect that some other inductor passed through the hole. \$\endgroup\$
    – Hot Licks
    Commented Nov 10, 2016 at 1:55
5 Answers 5
16
It's a once very common horizontal linearity adjstment for CRT raster scan TV sets.
It basically uses core saturation to achieve a somehow current dependent inductance. Bias magnet just changes current where saturation and hence "corrective" effect begins.
  • \$\begingroup\$ Thanks! And how do I google it? :D Can't seem to find anything alike on google images. \$\endgroup\$
    – Njubster
    Commented Nov 9, 2016 at 12:18
    \$\begingroup\$ @Njubster "linearity inductor" or "linearity coil" got me this page with a decent image. \$\endgroup\$
    – Ouroborus
    Commented Nov 9, 2016 at 17:05
12
In old tv sets you find a vertical and horizontal deflection system realized with inductors round the neck of the tv tube. The part in the picture comes from the horizontal or line deflection system.
A line deflection system consisted of two resonant circuits where the frequency was changed by means of a tube acting as a switch. These two circuits generated each half a cosine and switched over at the top. So one half of the cosine was a low frequency (the visible part on the screen) and the other half cosine the high frequency part (the invisible flyback part). What is needed for the visual part should be linear. This is not realy the situation with a cosine. Only a very small part of the cosine can be considered linear. To make the cosine more linear a magnetized adjustable inductor was placed in the circuit thereby improving the image on the screen.
  • 4
    \$\begingroup\$ This answer could greatly benefit from a sketch of the line deflection signal with and without the transformer. \$\endgroup\$
    – polwel
    Commented Nov 9, 2016 at 16:22
As others have said it is a biased inductor used in the non linear region of the ferrites B/H curve.
http://www.repairfaq.org/sam/deflfaq.htm#dshlc has a description, basically as the current in the deflection yoke rises the inductance of this part falls as it is driven further into saturation helping to reduce the effect on scan linearity of the copper losses in the yoke.
I think I found a similar inductor years ago.
If I remember correctly (you could check it easily), the round cylinder is a magnet, and can be rotated with a screw or a similar tool. My hypothesis was that it could change the DC component of the magnetic field in the main ferrite beam, and either change the self inductance or the limit of admissible current before saturation.
But I cannot answer what it is for.
  • \$\begingroup\$ Either it's too crusty, or it cannot turn. I'm afraid that I'll break it if I turn it stronger. And it's not a magnet, only the top is a magnet. Anyway, if it is a cylindrical / symmetrical, how come it changes anything? \$\endgroup\$
    – Njubster
    Commented Nov 9, 2016 at 12:02
  • \$\begingroup\$ @Njubster Could be loctight or such. Adjusted during assembly then fixed in place. Generally those kind of things screw in/out. The depth would control the amount of influence the magnet has. \$\endgroup\$
    – Ouroborus
    Commented Nov 9, 2016 at 17:10
  • \$\begingroup\$ Screwing the cylinder in or out changes its relative position to the coil that surrounds it (as well as the additional magnetic field that is present). \$\endgroup\$ Commented Jul 18, 2020 at 17:33
Resonant circuits (sometimes called 'tanks') are a combination of capacitors and inductors. The resonant frequency can be tuned by either varying the capacitance or the inductance. Big capacitors are expensive and prone to failure, so for high power applications, a large inductor is paired with two capacitors, usually in a "pi" configuration.
See https://en.wikipedia.org/wiki/LC_circuit for a broader interpretation, But the essential fact is that CRT magnetic deflection takes high voltage and the large inductor handles the higher power better than a capacitor solution. Because high voltage ages capacitors, but inductors hardly ever change (unless the ferrite slug gets adjusted).
After tuning, slugs are routinely fastened with Loctite or hard wax.
