6
"Short" question
Which flux type to use for SMD hobbyist (home-made) PCB?
  • How to know if a specific flux (e.g. F-SW-33) is no-clean or require cleaning.
  • How to know if a specific flux conduct electricity?
  • What is the impact of Halides?
Longer question, including context and previous researchs
I just had a hard time searching why my SMD circuits was not working properly, up to the moment I found the flux deposit was conducting enough to switch some transistors ON.
After some research, I found the following info:
  • Wikipedia flux specification differenciate types:
    • Base material: Resin, Organic, Inorganic
    • Corrosivity: not, weak, strongly.
    • With/Without Halides
    • Base component
    • etc.
  • Different types as:
    • no-clean (which unintuitively do not need to be cleaned)
    • water-soluble
    • etc.
On the other side; With my poor understanding of PCB fabrication, the process is simplified to:
  1. The circuit is printed (UV-positive painting, exposure, development, etching)
  2. I protect the circuit with some soldering mask/protection (recommended)
  3. Silk-printing (optional)
  4. Soldering (using flux)
  5. Cleaning of flux ?
But, how to clean below SMD small resistors or IC? That seem to me not an easy task. My conclusion is: Better use a no-clean flux, or at lest a non-conductive flux.
But which type match this specification?
This answer suggest that for electronic I should only use Rosin flux. Is that generally correct? or could an F-SW33 fill the task?
Are all the F-SW26 to F-SW32 equally good?
Related questions:
9
If a flux is "no clean" it means it doesn't, under normal circumstances, conduct electricity. The exception is when the flux gets burned by too high a temperature and turns brown. At this point it can start to conduct due to carbon deposits.
Water soluble flux conducts and must be cleaned before use.
My personal choice is to never use water soluble flux and to clean flux off with isopropyl alcohol as a matter of course.
I have two fluxes - one in a pen form and one in a syringe. I find I use the syringe one more than the pen one these days.
Both are Rosin based.
As always the exact properties and handling / cleaning instructions can be found in the datasheet.
Fluxes designed for metalwork, such as soldering pipes, is generally an acidic flux and must never be used on PCBs or it will corrode things horribly. Only ever use electronic-grade flux.
  • \$\begingroup\$ Thanks for your great answer. Do you know about the Halides: why is important its existence in the flux? \$\endgroup\$ Commented Nov 18, 2016 at 12:12
    \$\begingroup\$ Halides are generally what makes plumbing/metalwork flux be flux. They're generally corrosive. By the way, search for "halides" in the wikipedia article you've linked to. \$\endgroup\$ Commented Nov 18, 2016 at 12:18
  • \$\begingroup\$ @MarcusMüller: If I understand, I am better at using a halides-free flux for long time reliable pcb. But it could make the soldering more difficult. \$\endgroup\$ Commented Nov 18, 2016 at 12:20
    \$\begingroup\$ No. Seriously, Majenko's answer isn't that unclear. Use flux that is no-clean, and most importantly, electronics flux. Halide-containing flux is never no-clean, and in 99.95% of times not even electronics flux. \$\endgroup\$ Commented Nov 18, 2016 at 12:22
    \$\begingroup\$ @MarcusMüller: thanks, the part of "Halides-containing flux is never no-clean" is the part I was missing. \$\endgroup\$ Commented Nov 18, 2016 at 12:34
How to know if a specific flux (e.g. F-SW-33) is no-clean or require cleaning. Usually it will tell you in the datasheet, or the manufacture will mention it on the product page, if it doesn't have a product page or manufacturer information, then don't buy it. F-SW-33 flux ( or Fluxi FL 110) does not have a datasheet that I could locate, and does not have specs on how it preforms in a manufacturing setting (probably geared for prototyping). It is listed as a no-clean flux on farnells website.
It is also important to note that if you are doing prototyping, you may want to also use the same flux as your assembler if the design might be sensitive to flux degradation. (same thing also applies to solder) I've been bitten once by that, and this is just one variable to eliminate
There isn't a resistivity spec given to most fluxes, if you want to know that you will have to test it yourself. There are two applications that flux residue could be a problem:
1) leakage current in high resistivity applications like ph meters or electrometers, where you are counting electrons. 2) Changing the capacitance of RF applications, a residue might affect the few pF's that need to be tightly controlled in the GHz range
In these situations it would be best to use a water soluble process or flux with solvent cleaning and avoid the issue of no-clean flux residues.
There are a few other problems with fluxes, they become conductive when placed in high humidity environments, with some having resistivities in the kΩ range (disturbing eh?)
The industry is aware of this and does preform testing, if your product is going to be in a high humidity environment, make sure it has been tested with the appropriate
Surface Insulation Resistance (SIR) testing is a methodology used to characterize the PCB manufacturing and electronics assembly process residues and their impact on reliability. It is usually performed on industry standard test board coupons containing patterns, typically interlocking comb test patterns designed for process testing purposes. The patterns are exposed to a high humidity environment which mobilizes any surface contaminates and reduces the insulation resistance of the test pattern.
Source: https://www.nts.com/services/testing/electrical/sir-testing/
Halides can wick/travel up the pins of an IC and into the wires and onto the die of an IC via electromigration. If the component is particularly sensitive to halides (like chlorine, or fluorine) then it can disable or destroy the functionality of that component. Halides typically affect components like optical components, that use different processes and chemistries than those of silicon IC's. The manufacture will generally set the halide limit, and mention it in the components datasheet.
Avago has a nice write up on this.
I use a water soluable flux and clean my parts with DI water (this process is not acceptable for high MSL (moisture sensitivity level) parts. But I know I'm getting all of the flux off. The problem is with assembly, most manufacturers are moving to no-clean due to be environmentally friendly (no CFC solvents). Another thing to do is use techspray flux remover which gets most everything off your board. If your worried about residue for any reason, then don't use it. IF your design can take some abuse (all digital) then don't worry about it.
A rosin flux with a good flux remover solvent is another good way to make sure you have no residue, if you spray it down enough and use enough solvent.
