I'm new to FPGA and VHDL. I'm using Xilinx Spartan 3A.
I have wrote a custom ROM with initalization file .hex. I would like to verify that the rom is initalized with the values in the .hex value. Is there a method to verify the contants that is loaded from the file.
here is my design file LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY rom IS
PORT (address: IN INTEGER RANGE 0 TO 15;
data_out: OUT STD_LOGIC_VECTOR(7 DOWNTO 0));
END rom;
ARCHITECTURE rom OF rom IS
SIGNAL reg_address: INTEGER RANGE 0 TO 15;
TYPE memory IS ARRAY (0 TO 15) OF STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL myrom: memory;
ATTRIBUTE ram_init_file: STRING;
ATTRIBUTE ram_init_file OF myrom: SIGNAL IS "test.coe";
BEGIN
data_out <= myrom(address);
END rom;
I have used a test bench and I tried to simulate a ROM using initialization file but I get undefined output according to that image.
Test bench:
-- Entity
library ieee;
use ieee.std_logic_1164.all;
entity tb is
end entity;
-- Architecture
library ieee;
use ieee.numeric_std.all;
architecture sim of tb is
-- Clock and reset decl.
-- Clock
constant CLK_FREQ : real := 100.0E6; -- Clock frequency in Hz
signal clk : std_logic;
-- Reset
constant RST_PER : time := 100 ns; -- Reset period; and then waiting for rising clk edge before deassert rst
signal rst : std_logic;
-- Device Under Test (DUT) decl.
signal dut_address : integer range 0 to 15;
signal dut_data_out : std_logic_vector(7 downto 0);
-- Test control decl.
-- None
begin
-- Clock and reset impl.
-- Clock generation
process is
begin
while true loop
clk <= '1';
wait for 0.5 sec / CLK_FREQ;
clk <= '0';
wait for (1.0 sec / CLK_FREQ) - (0.5 sec / CLK_FREQ);
end loop;
end process;
-- Reset generation
process is
begin
rst <= '1';
wait for RST_PER;
wait until rising_edge(clk);
rst <= '0';
wait;
end process;
-- Device Under Test (DUT) impl.
rom_e : entity work.rom
port map(
address => dut_address,
data_out => dut_data_out);
-- Test control general
process is
begin
-- Wait for reset release and clock.
wait until rst = '0';
-- Address apply and data output check
for address in 0 to 15 loop
dut_address <= address;
-- Check output of ROM
end loop;
-- Run for a while
wait for 1 us;
-- End of simulation
report "OK ########## Sim end: OK :-) ########## (not actual failure)" severity failure;
wait;
end process;
end architecture;
/tb/rom_e/myrom
the first two locations in memory myrom are all 'U's which is a strong indication you haven't initialized it. \$\endgroup\$
