Good Morning,
I'm developing a bio-impedance system. To perform the impedance calculation, I am trying to use the method described in this article, and mentioned below: http://www.ijirset.com/upload/2015/july/112_Body.pdf
  • An electrical signal is injected into the patient's body through 2 electrodes, and the same signal is collected through 2 other electrodes.
  • This collected signal is then connected to the Arduino ADC, and n samples of that signal are acquired.
  • The Frequency spectrum is found from which FFT is calculated in MATLAB.
  • So, according to the article mentioned above, Least curve fitting method is used for the estimation of impedance value. The result of calculation is a single complex number containing real and imaginary values of the impedance. These real and imaginary values will be applied in equations later.
My question is, how should I apply the method Least curve fitting, to the N complex numbers returned from the FFT calculation?
I have as a result of FFT a complex vector of 1x2048.
I took a look at the documentation of matlab: https://www.mathworks.com/help/optim/ug/lsqcurvefit.html
But I did not understand how to configure the parameters (fun,x0,xdata,ydata) of the lsqcurvefit function, in my case.
Thank you very much!
    \$\begingroup\$ Figure 1 in that graph is great, isn't it. A plot with no axis labelling, no units, no description. If you have single frequency excitation, then there's no need for the overhead (either computing or conceptual) of an FFT. A single frequency complex correlation between the drive current and sense voltage will give you impedance directly. Curve fitting means you assume a low order model describes a large number of data. The model you assume is a vital input to this process. The model doesn't fall out of curve fitting. Assuming your model means creating the 'fun' parameter for the fitter. \$\endgroup\$
    – Neil_UK
    Commented Nov 23, 2016 at 8:50
  • \$\begingroup\$ Thanks for the answer. I'm using a single frequency of 50kHz. I believe I need the FFT to extract the complex values ​​of my signal (real and imaginary). What do you suggest me to calculate the impedance ?, from the n complex numbers that I obtained through the FFT. I need a single complex value. \$\endgroup\$ Commented Nov 23, 2016 at 12:29
  • \$\begingroup\$ added an answer to clarify what I meant, though I made the mistake of calling convolution 'correlation' in my comment. They are very similar, but time is reversed in one! \$\endgroup\$
    – Neil_UK
    Commented Nov 23, 2016 at 14:51
The FFT is simply an efficient method for computing the DFT (Discrete Fourrier Transform), which is a convolution between an N sample input waveform \$ x_n\$, and each of the N complex basis functions of the form \$ u_n=exp(i2\pi fn)\$, where f is the frequency and varies from 0 to N-1.
The niave, direct, brute force way of doing the DFT requires \$O(2N^2)\$ multiplies and adds. The FFT uses a clever factorisation to radically reduce the number of adds and multiplies required to \$O(2N \log_2(N))\$, worth doing if N is more than few dozen, and you need all the frequencies.
If you only need the convolution at a single frequency, or a small handful of frequencies, then doing it directly, doing just one frequency of the DFT, is quicker than using an FFT, which is an 'all or nothing' calculation.
For instance, to compute the complex gain v/i at a single frequency, you would start by effectively generating a complex signal at that frequency, and output the real component of it to the device under test. 'Effectively' means that you do not actually need to explicitly generate the full complex cosine+sine signal. If the period is a multiple of 4 samples, that means you can generate just the cosine waveform, and shift it by 90 degrees, or just index it shifted, to get the sine for free.
Once you have the received the \$v_n\$ waveform, you convolve it with the complex reference \$u_n\$. This has real part \$cos(2\pi f n)\$ and imaginary part \$i.sin(2\pi f n)\$. The convolution as done as $$realpart= \sum_{n=0}^{N-1}v_n.cos(2\pi fn)$$This is the part of v that's in phase with the stimulus signal. You get the imaginary, quadrature, part by doing the same summation having substituted sin() for cos() as $$imagpart= \sum_{n=0}^{N-1}v_n.sin(2\pi fn)$$You of course do not need to compute the cos(2pifn) when doing the sums, it reduces to indexing through your waveform one sample at a time!
In C, the algorithm is
float* v_ptr = v_buffer;
float* real_ptr = &cos_table[0];
float* imag_ptr = &cos_table[OFFSET_FOR_SINE_START];
float real_sum=0, imag_sum=0;
for (i=0; i<N; i++){
    real_sum += *real_ptr++ * *v_ptr;
    imag_sum += *imag_ptr++ * *v_ptr++;
As a detail, the above assumes that cos_table is long enough so that sine can index it to the end after starting 1/4 cycle in. You would have to do something tricky if it was only N long.
As this computation is exactly the same, at that frequency, that the FFT does at all frequencies, it is subject to the same limitations of periodicity. That means if your waveform is not periodic in your chosen analysis vector length N, then your convolution results will be inaccurate. In the FFT this is manifested as 'spectral leakage'.
As in the FFT, there are two solutions to this. The first is to ensure that your N sample waveform always contains an integer number of cycles. This is easy when you are generating your own waveform! When the signal is not under your control, windowing is usually used prior to the FFT to reduce spectral leakage.
