I am trying to multiplex two seven segment displays, once a switch input is detected.
- If a switch is pressed then the seven segment displays should show
- If pressed again,
, then3
and so on.
My problem arises when I reach number 9
since the next switch input will show 10
. 1
on the first SSD and 0
on the second SSD. Below is a snippet of my code with regards to how I am detecting inputs from 1 - 9.
int k = 0;
unsigned int SW1;
PINSEL0 = 0; //Set P0.0 - P0.15 as GPIOS
PINSEL1 = 0; //Set P0.16 - P0.31 as GPIOS
IO0DIR = 0xFFFFF9FF; //Setting P0.9 as input for SW1
while (1)
SW1 = IO0PIN & 0x00000200; //switch connected on P0.9
if ( SW1 != 0x00000200 ) //when pressed
k++;
IO0SET = T1;
IO0SET = T2;
if (k == 1){
IO0SET = T1; //switching on left seven segment display
IO0CLR = T2; //clearing the right seven segment display
IO0CLR = a;
IO0SET = b;
IO0SET = c;
IO0CLR = d;
IO0CLR = g; //displaying number 1
IO0CLR = e;
IO0CLR = f;
small_delay();
I am following the same structure for the 10th switch press:
else if (k == 10){
IO0CLR = 0x000000FF; //turn off all the segments as well as both common anodes. Then your outputs will be ready for the new segment patterns to be set up.
IO0SET = T2; //switching on first display
IO0SET = b;
IO0SET = c; //displaying number 1
small_delay(); //calling short delay
IO0CLR = 0x000001FF;
IO0SET = a;
IO0SET = b;
IO0SET = c;
IO0SET = d; //displaying number 0
IO0SET = e;
IO0SET = f;
IO0SET = T1;
small_delay();
IO0CLR = 0x000000FF;}
The problem with the second code I provide is that the seven segment display only displays 10
once. That is, first 1
is shown on the left display and then 0
on the second display as required, however this is performed only once and does not go on until the next switch input is detected.
One solution this problem which I have come up with is that I included a while statement after the if else
such that:
else if (k == 10){
while (k == 10) { //rest of code
This actually does what I want it to do, and keeps multiplexing both seven segments, showing number 10
, however the problem in this case is that it does not step out of the while loop to accommodate for the next switch input.
How can I multiplex both displays until the next switch input is detected? Any ideas/suggestions would be greatly appreciated.
