I am trying to build a boost converter using LT3517 with 5V input. LED and input voltage(5V) is constant for our application. I need to tune the circuit between this and the current across the LED should be 500mA as per our application. so I put 1.65 ohms current sense resistor.
But 5V input is not switching/boosting the voltage. can i know the reason for it?
what is the mistake i made in the below circuit? How can I boost my voltage?
