I am asked to find the impedance of an unknown load. The precise formulation is provided below:
The following two step procedure was used to measure the value of an unknown load \$Z_{L}\$. The characteristic impedance of the feeding line is \$Z_{0}=100\Omega\$.
- First \$Z_{L}\$ was disconnected and an input impedance \$Z_{in}=-j150\Omega\$ was measured.
- Next, \$Z_{L}\$ was connected and an input impedance \$Z_{in}=(100-j50)\Omega\$ was measured.
Find \$Z_{L}\$ both analytically and graphically using a Smith chart.
My problem is that my analytical solution doesn't match the graphical one using a Smith chart and I cannot figure out the reason for the discrepancy.
Solving it analytically I tried using the formula for \$Z_{in}\$. First, for the open circuit,
$$-j150=\frac{100}{j\times tg(\beta\times l)}=-\frac{j100}{tg(\beta\times l)}$$
which yielded \$tg(\beta\times l)=\frac{2}{3}\$.
I then used the same formula for the second measurement:
$$100-j50=\frac{Z_L+j\times 100\times \frac{2}{3}}{100+j\times Z_L\times \frac{2}{3}}$$
which yielded \$Z_L=2.63+j151.27\$.
Using a Smith chart I applied the following procedure: I first marked on the diagram the point \$-j1.5\$ as the normalized \$Z_{in}\$ and then moved from the left end of the diagram (open circuit) clockwise till I reached that point. This yielded a length of \$0.344\times \lambda\$ for the transmission line. I then marked the second normalized \$Z_{in}\$ (\$=1-j0.5\$) and drew a circle of that radius. From \$1-j0.5\$ I began moving counterclockwise (toward load) a distance of \$0.344\times \lambda\$ to reach my unknown \$Z_L\$. Unfortunately, the result was different than that found analytically.
Does anyone have an idea what I might be doing wrong? I'd appreciate any advice.
