Determine the value of the resistance R in the circuit shown below, given that Req = 9 ohms.
I called the top-left, top-right and middle-right nodes a, c and b respectively, and did a delta-Y transformation on the 24-ohm, 4-ohm and R resistor. I got that R3 and the 8-ohm resistor are in series, but now I'm completely stuck on trying to figure out how the empty wire in the middle of the circuit gets simplified.
If my understanding of parallel is correct then I think the wire is in parallel with the 30-ohm resistor because both ends connect to each other, so the equivalent resistance would be 0 and I could cancel out the 30-ohm resistor completely. But if that's true, then by the same reasoning wouldn't the wire also ultimately short everything above it including R? And if it's not in parallel with the 30-ohm resistor, how can I simplify anything?
