When soldering SMD components, the 2-pinned ones (like resistors, capacitors, ...) are the hardest in my opinion.
I started long time ago with the 1206 format. Then scaled down to 0804, 0603 and finally I'm working with the 0402 ones.
I'm facing a new challenge right now. Once I get some flux on my tweezer points (it happens all the time), they get really sticky. This leads to numerous problems.
If I'm really lucky, I grab the part first time right. This means that I grab the part by its middle, and I can move it to the pads for soldering:
Misery starts when I grab it wrong first time. "Wrong" can be many things: I grab it by the side, it's not aligned well to the eventual target, ... Anyway, the moment I want to release, I open my tweezers and the part keeps sticking to either side of the tweezer points.
Has anyone experienced the same problem? What was your solution?
EDIT
Here are some ideas that might inspire you..
Tweezer material or coating
I've found a pair of tweezers online like this: These tweezers features a "Stainless Steel Body" and "Carbon Fibre Tip". Will this tip material help to prevent the stickiness?
Perhaps you're using tweezers with some special coating?
Super hydrophobic coating
Maybe this is a bit strange, but did anyone experiment with a "super hydrophobic coating" on its tweezers? I believe this should help to avoid any liquid/flux from sticking to the tweezer points. I've discovered some sprays online (http://www.neverwet.com/) but haven't bought any of them yet. Would they work on a pair of tweezers?
Tweezer form
To avoid stickiness, would you recommend a very fine tip? Curved or not? If curved, curved inwards or sideways?
Tweezer tip roughness
Some tweezers have polished points, others are more rough. What is best?
Demagnetization
Some tweezers claim to be "antimagnetic". Does this feature really help?
