For a highly-sensitive electrometer one needs not only high resistance but also a really small capacitance to achieve certain AC behavior e.g. stability of the opamp.
The figure below shows a typical example of a electrometer circuit with an opamp and can be extracted from this Analog Devices application note.
This is equal to the following circuit.
The values given in the schematics plus the noise budget calculations I did, result in a output range (worst-case, \$T_A = 25°C\$) from \$320\, µ V\$ (noise floor) up to \$ 3.3 \, V\$ when a dual power supply (\$V_+=3.3 \, V\$ and \$V_-=-3.3 \, V\$) is used. According to simulation a \$3 dB\$ bandwidth of \$ 530.52 \, Hz\$ works well for a pulsing of the input signal with \$ 200 \, Hz\$. The idea is suppressing noise below this frequency as you mix your signal up from \$0 \, Hz\$ to a higher \$f_{IF}\$. The bandwidth of the system is mainly determined (or from a ideal POV only determined) by the feedback capacitor and can be calculated with
$$f_{3dB} = \frac{1}{R_f C_f 2 \pi}$$
So the capacitance needed is in the femtofarad range (\$30 \,fF\$). Now my question is if you have a feedback path (cf. picture), where you want to avoid coupling impedances (to somewhere outside of this low-current path) of any kind (you use all kind of fancy guarding techniques e.g. via fencing) would you say it is legitimate to use an embedded, self-made pcb cap? You know like basically two plates on TOP and BOTTOM.
I mean the calculations say, that for \$30 \, fF\$ you need two plates with an area of approx \$1.153 \, mm^2\$ when you use FR4 (\$\epsilon_r = 4.7\$) and a PCB with \$1.6 \, mm\$ thickness.
So you have
$$ C = \frac{\epsilon A}{d} $$
which can be rewritten as
$$ A = \frac{C d}{\epsilon} $$
If I got it correctly you can just draw two squares on the PCB on both sides, each of them has the following dimensions $$\sqrt{A} \cdot \sqrt{A}.$$
Conclusion: Can I use an embedded capacitance when working in the femtoampere (YES \$10^{-15}\$ A) range or am I missing out on something here? It is quite hard to get such small capacitances, which is the reason why a embedded capacitor shall be used.
