I need to manually solder with a soldering iron an LFPAK56, Power-SO8 package MOSFET. I am reading that the maximum junction temperature for the device is 175C.
The soldering iron goes way over that temperature but of course the Tj temperature is define for when the MOSFET is in operation. Soldering maximum temperature must be much higher.
Wave soldering has a maximum temperature of about 260C for some 10 seconds. The MOSFET drain is quite a massive piece of metal and must be heated enough to permit solder melt. Is it even possible to solder such a device manually without overheating to destruction?
- What is the maximum device temperature possible before a MOSFET starts degrading during manual soldering?
- How long can it endure such a high temperature?
