I am trying to understand how to add the background noise into the equation. I am trying to work out the pathloss of a radio signal over a certain distance.
We have the Friis Formula for that for example. Now the Friis Formula has 2 parameters for the gains of the receiver and transmitter antenna. I don't necessarily know whether the antenna gain variable contains or is influenced by the atmoshperic noise. I think it's just the internal noise inside the antenna, like how a not perfect conductor will generate heat and that loss can interfere with the signal.
But even then to just be safe I like to use the maximum gain formula, as in the fundamental limit on the antenna gain for a theoretically perfect antenna, which I have talked about and asked some questions about here.
Ok so I read this paper:
- "Atmospheric Magnetic Noise Measurements in Urban Areas" (2014) - Christian Schlegel, Matt Mallay, and Chris Touesnard
Where they break down the background noise, in this case the magnetic noise into 2 parts:
- Thermal ( the heat energy in the air)
- Atmospheric (micropulsation of the Earth's magnetic field)
They both disrupt the signal of the antenna, and basically at lower frequencies you have more atmospheric noise ,and in higher frequencies you get more thermal or even man made noise, at very high frequencies you get cosmic noise.
- David Gibson also wrote an interesting paper on this: "Channel Characterisation and System Design for Sub-Surface Communications" (2003)
To keep it short, the formula is basically this:
$$F_a(f) \approx 294.15 - 36 \log_{10}f $$
I have checked it, it matches the data of both Gibson's research and that of the 2014 paper, which has experimental evidence, although there is a 20 db difference between indoor and outdoor noise. Gibson's research relies on the 1968 CCIR study, which might be obsolete now as the electromagnetic spectrum with all the new technologies affecting it have changed.
Question
The question is this: Could I consider this atmospheric noise as a fundamental minimum in dB that a signal has to have in order to be able to be detected by an antenna.
For example this formula says that a 1 Hz signal will have ~ 294.15 dB level noise interference, so would this mean that the receiver antenna has to receive higher than 294.15 dBW signal, probably way higher, in order to establish a communication channel. I mean the level of the noise would totally overwhelm any signal that would have a power level lower than this and it would be impossible to send information through.
So going with the Nearfield formula that I've talked about in my previous question:
- A 1 Hz magnetic signal, going between 2 magnetic antennas placed 50 centimeter from eachother with a boundary sphere of 20 cm has a path loss of roughly 16 dB
- Now inserting the atmospheric noise component, which is 294.15 dB (probably +20 dB higher in a building)
- Would this mean that the total attenuation of the signal in this case is 310.15 dB? And note that this is the minimum attenuation, since we used the maximum possible gain for the antennas, and in reality the gain will be much lower, so the attenuation would be much higher. Also this would be the attenuation of the signal, the antenna would still receive the energy, it's just that you could not decode it due to the overwhelming noise interference.
