I'm considering re-implementing my thermistor measurement circuit to be isolated, since it's destined for an industrial environment. The thermistor is a simple passive sensor and is not grounded on the far end.
U1 is a 5V/5V regulator rated for 3kV isolation. The line out to the thermistor is connected to protection shottkys, a TVS zener, and caps that set the time constant at (I think) ~1s.
U3 is a "linearized" optoisolator rated to 3.75kV isolation.
Back-of-the-envelope calculations for the following nominal values:
- the input and output of U2 at 2.5V,
- the LED current at 8.7mA,
- Irm1 = Irm2 = 90uA,
- line time constant = 853ms
Questions:
- Have I made any mistakes in how the circuit is connected or the passives are chosen?
- Is it even necessary for this isolation to be done, given that the far end does not have its own ground?
- Are there any rules I should follow with regard to PCB layout (especially shuffling around the diodes and caps, etc.)
