Can someone explain to me how this (as advertised) full bridge load cell works?
I'm aiming for good temperature stability and I understood a full bridge load cell configuration should reject error from temperature variation based on the fact that you're measuring the difference between two elements.
This particular load cell varies by about 1% per 1°C.
I'm struggling to see how this configuration is an improvement over a single, 2-wire resistive element at all.
