TL,DR: Use a comparator, not an opamp. See Frosty's answer below.
I'm trying to make a pulse waveform generator with variable duty cycle. The 555 timer is used to generate a sawtooth waveform, which is then compared to a constant voltage from a voltage divider. The schematic works in principle, but for some reason the output of the opamp has a very low slew rate.
This is the schematic:
Vcc is 5 volts. R1, R2 and C1 are such that the width of one tooth of the sawtooth waveform is roughly 200 microseconds (I'm seeing that with the scope). However it takes roughly 10 microseconds for the output of the opamp to go from 0 volts to 4 volts.
The opamp in question is TL072, which, according to its datasheet has a typical slew rate of 13V/us. There's also a graph that is showing "Normalized slew rate", which is roughly 1V/us at +/-15V power supply.
Am I misunderstanding what slew rate really is? Shouldn't this amplifier go from 0 to 4 volts in about 0.3 microseconds?
UPDATE: The circuit behaves as described with no load.
