I'm trying to simulate a band-pass transconductance amplifier in LTSpice, which looks like this:
I used the recommendations of this post - https://electronics.stackexchange.com/a/278870/87695 - and used a G component with a table to represent the voltage controlled current source in my LTSpice schematic.
I have done some estimations on the locations of the poles and zeros:
However, my simulation is not displaying the result I expect to see at all:
I suspect that I set up the voltage controlled current source incorrectly. Here are the parameters:
Any idea of what I did wrong? Thanks in advance.
table()
, so you can just replace the whole line with0.1
. BTW, behavioural sources, while versatile, can prove sluggish the higher the numbers, and their dynamic range, both on y and x axis, are reduced. Using aG
source is the most accurate and fastest way to do it. Behavioural sources are good when there are more complicated expressions. \$\endgroup\$
