I have a project that has 18 of these common-cathode displays, 36 digits in all, organized into three rows of 12 digits. My first version of the project used an Arduino and shift registers to drive them. I would shift out the 0th column of digits, latch them to provide power to the displays, then ground the 0th column. This would show the first character. Then, I'd shift out the next column of data, disable the ground on the 0th column, latch the 1th column, and provide ground to the 1th column to show it to the user.
It works, but it has a couple issues. It's very, very, very dim. I can make it brighter by holding each display on a while longer, but it doesn't go very far, and you can sense the low refresh rate when you look at it. Also, if I have a column that have very few segments active, they draw all the current I'm supplying and that column ends up being much brighter than the rest.
I have a ton (would you say I have "a plethora?") of MAX-7219 LED controllers, but there's a snag: the LED controller assumes a maximum of 8 segments per cathode. I considered using one LED controller to drive half of the segments on 8 digits, and another controller for the other half. This would (probably) work - I'd just deactivate the display on the upper half and activate the lower, then reverse the process a few milliseconds later.
I really want the drawing to be fire-and-forget. I have to generate the data I'm displaying, and this takes time. During this time, I can't really be burning CPU, flopping the displays. (Technically, I could do the flopping in a timer, but I'd have to stop the timer while I shifted out new data, and that timer might interfere with the LedController library, as well as the serial communications I'm using to get the data from a GPS module, anyway.)
So, is there a way that I can shift out 36 digits worth of data and completely forget about it for 100-1000ms, leaving the work of driving the display to someone else's hardware? I've even considered having one arduino to process data, then transfer it, somehow, to three - or even six - other arduinos for display.
