I've two Vibro Graver electric engravers (120V 60Hz) with me. I gave one to a friend who recently moved to another country. He got a step down converter from 220V to 110V but then he noticed the frequency used there is 50Hz.
What would the effects of using the device on a 110V 50Hz supply when the device is meant to be used on 120V 60Hz supply. Does the 10Hz difference cause any damage?
Edit: The voltage is stepped down from 220V 50Hz to 110V 50Hz Img 1
