I need to read several analog sensors on a Arduino Mega ADK. I want to use a multiplexer for this (CD74HC4067E), see the schematics.
The output however from the multiplexer channels is not consistent with the output which i read directly from on the analog input:
Through the Mux x: 333 y: 276 z: 323 Direct analog readings x: 328 | y: 334 | z: 285
Through the Mux x: 333 y: 276 z: 321 Direct analog readings x: 328 | y: 335 | z: 277
Through the Mux x: 334 y: 276 z: 322 Direct analog readings x: 329 | y: 335 | z: 277
Through the Mux x: 333 y: 276 z: 324 Direct analog readings x: 328 | y: 334 | z: 283
Through the Mux x: 333 y: 276 z: 299 Direct analog readings x: 329 | y: 335 | z: 282
ALthough it might seem that there is a wiring problem (simply switch X and Z), my setup is correct (triple checked!).
When i turn the sensor 90 degrees clockwise so that Y is up, i get the following:
Through the Mux x: 334 y: 344 z: 270 Direct analog readings x: 266 | y: 334 | z: 344
Through the Mux x: 334 y: 345 z: 269 Direct analog readings x: 265 | y: 334 | z: 344
Through the Mux x: 333 y: 343 z: 271 Direct analog readings x: 264 | y: 333 | z: 343
Through the Mux x: 335 y: 344 z: 270 Direct analog readings x: 265 | y: 334 | z: 344
so it seems that the X and Z pins should be switched.
I can i improve this?
And my arduino code:
//to hold direct read from the analog output of the ADXL335
int xAnaRead;
int yAnaRead;
int zAnaRead;
//to hold readings from the mux:
int xMuxRead;
int yMuxRead;
int zMuxRead;
//mux pins
int s0 = 8;
int s1 = 9;
int s2 = 10;
int s3 = 11;
//The pin on which the Mux outputs
int SIG_pin = A0;
//Analog read pins
const int xPin = A8;
const int yPin = A9;
const int zPin = A10;
void setup(){
Serial.begin(9600);
void loop(){
//read value on channel 0 of Mux
xMuxRead = readMux(0);
//read analog value
int xAnaRead = analogRead(xPin);
delay(100); //to let the capacitator discharge
//read value on channel 1 of Mux
yMuxRead = readMux(1);
//read analog value
int yAnaRead = analogRead(yPin);
//read value on channel 2 of Mux
zMuxRead = readMux(2);
//read analog value
int zAnaRead = analogRead(zPin);
//Output the readings
Serial.print("Through the Mux x: ");
Serial.print(xMuxRead);
Serial.print("\t y: ");
Serial.print(yMuxRead);
Serial.print("\t z: ");
Serial.print(zMuxRead);
Serial.print("\t\t Direct analog readings x: ");
Serial.print(xAnaRead);
Serial.print(" | y: ");
Serial.print(yAnaRead);
Serial.print(" | z: ");
Serial.print(zAnaRead);
Serial.println("");
delay(100);//just here to slow down the serial output - Easier to read
//this is verbose but it works, and is more readable (i need that :)
int readMux(int channel){
int controlPin[] = {
s0, s1, s2, s3 };
int muxChannel[16][4]={
0,0,0,0 }
, //channel 0
1,0,0,0 }
, //channel 1
0,1,0,0 }
, //channel 2
1,1,0,0 }
, //channel 3
0,0,1,0 }
, //channel 4
1,0,1,0 }
, //channel 5
0,1,1,0 }
, //channel 6
1,1,1,0 }
, //channel 7
0,0,0,1 }
, //channel 8
1,0,0,1 }
, //channel 9
0,1,0,1 }
, //channel 10
1,1,0,1 }
, //channel 11
0,0,1,1 }
, //channel 12
1,0,1,1 }
, //channel 13
0,1,1,1 }
, //channel 14
1,1,1,1 } //channel 15
//loop through the 4 sig
for(int i = 0; i < 4; i ++){
digitalWrite(controlPin[i], muxChannel[channel][i]);
//read the value at the SIG pin
int val = analogRead(SIG_pin);
//return the value
return val;
