A simpler and more direct implementation would be:
library ieee;
use ieee.std_logic_1164.all;
entity TFF is
port(
CLK : in std_logic;
RST : in std_logic;
T : in std_logic;
Q : out std_logic;
Q_N : out std_logic
end entity TFF;
architecture behaviour of TFF is
signal tState : std_logic;
begin
pFlipFlop : process(RST, CLK) is
begin
if (RST = '1') then
tState <= '0';
elsif (CLK'event and CLK = '1') then
if (T = '1') then
tState <= not tState;
end if;
end if;
end process pFlipFlop;
Q <= tState;
Q_N <= not tState;
end behaviour;
but this introduces a delta delay onto Q_N which may be a problem if this feeds another CLKed flip-flop input.
Alternatively, you could use the below but it may implement more than one flip-flop, though synthesis optimisation should reduce it to one.
library ieee;
entity TFF is
port(
CLK : in std_logic;
RST : in std_logic;
T : in std_logic;
Q : out std_logic;
Q_N : out std_logic
end entity TFF;
begin
begin
if (RST = '1') then
tState <= '1';
Q <= '0';
Q_N <= '1';
if (T = '1') then
Q <= tState;
Q_N <= not tState;
end if;
end if;
end behaviour;
